Aktuelle Zeit: Samstag 15. August 2026, 03:23
 Betreff des Beitrags: kkl + webasto 24 volt ?
BeitragVerfasst: Dienstag 23. November 2010, 13:23
Hello,
A couple of questions from a newbe :
If my unit ( airtop 2000st ) is 24 volt is the W bus also 24 volt ? high state is 24 volt ?
If i change the 510 ohms(r4 / r6 ) on my interface does this mean i can use 24 volt as main power
os is this just for wbus ?
tnx
Luc
 Betreff des Beitrags: Re: kkl + webasto 24 volt ?
BeitragVerfasst: Dienstag 23. November 2010, 20:09
It's a good question. I think it can be 24 V. Best way is to measure it with a scope. Or just try it with two 1k resistors.
BeitragVerfasst: Dienstag 23. November 2010, 21:16
I just measured on the webasto airtop , pin 5 of x 6 (w bus) gives 23 volt DC, can the kkl handle this voltage you think ? or should
the voltage of the bus be the same as the VB+ ?
As i can see in the sheet of the l9637 it should not be a problem ( but i toasted one over here so there is somethink stange going on) .
What is the function of R4 ?
lots of questions :)
Tnx for the quick reply !
luc
BeitragVerfasst: Mittwoch 24. November 2010, 10:16
+VB must be ~24 V
R4 and R6 must be 1 kOhm
BeitragVerfasst: Mittwoch 1. Dezember 2010, 20:41
just connected my new kkl with 1 k resistors to my airtop 2000 st 24 volt, works perfect !!
tnx
luc
