 Betreff des Beitrags: rpm-signal from engines or gear-box
BeitragVerfasst: Mittwoch 3. Februar 2016, 17:22
By the way, just another question:
for my job I need a high-resolution rpm-signal from engines or gear-boxes. Most engines have a sensor for that at the crackshaft, e.g. with 64 pulses per revolution of that shaft.
Do you know of a way to get information from that sensor on can-bus in that resolution?
A value in rpm with only slow rate is way to slow. I need exact angles of a shaft.
Regards,
Christoph
BeitragVerfasst: Mittwoch 3. Februar 2016, 18:15
Ich habe ein neues Thema daraus gemacht. Infos zu CAN messages habe ich nicht. Aber die Leute bei http://www.canhack.de/ sind die richtigen Ansprechpartner
