I did not see any profit in this. It's a diagnostic device and there is no need for diagnostic to use a fast mode. The other problem is Bluetooth: It's not so fast as a cable connection can be (this is the reason why the firmware update need so much time instead of a update via cable).
Well, i'm very disapointed of this, because i don't use WBH BT5 for diagnostic fonction. It's for me a LOG tool.....so i see a lot of profit to make it the fastest as possible.
Never mind, i respect your point of view, about "YOUR" device....and you're right, the BT is probably a hard limitation in FPS...
I'll try to make my own with arduino.....
Thank's for all.
SKOLS
