Aktuelle Zeit: Sonntag 20. September 2026, 17:10
 Betreff des Beitrags: Fehler beim copilieren der OBD2.C
BeitragVerfasst: Montag 6. Februar 2006, 21:39
nettes Projekt mit dem OBD_LCD.
Leider habe ich immer Fehlermeldungen mit "unused variable" beim compilieren mit Programmers Notepad von WinAVR.
Hier mal die Meldung komplett:
> "make.exe" all
-------- begin --------
avr-gcc (GCC) 3.4.3
Copyright (C) 2004 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling: obd2.c
avr-gcc -c -mmcu=atmega8 -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=obd2.lst -std=gnu99 -MD -MP -MF .dep/obd2.o.d obd2.c -o obd2.o
obd2.c: In function `get_pids':
obd2.c:170: warning: unused variable `texte'
obd2.c:171: warning: unused variable `mem_dummy'
obd2.c:172: warning: unused variable `i'
obd2.c:172: warning: unused variable `ii'
obd2.c:172: warning: unused variable `cnt'
Linking: obd2.elf
avr-gcc -mmcu=atmega8 -I. -gdwarf-2 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=obd2.o -std=gnu99 -MD -MP -MF .dep/obd2.elf.d obd2.o --output obd2.elf -Wl,-Map=obd2.map,--cref -lm
Creating load file for Flash: obd2.hex
avr-objcopy -O ihex -R .eeprom obd2.elf obd2.hex
Creating load file for EEPROM: obd2.eep
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O ihex obd2.elf obd2.eep
Creating Extended Listing: obd2.lss
avr-objdump -h -S obd2.elf > obd2.lss
Creating Symbol Table: obd2.sym
avr-nm -n obd2.elf > obd2.sym
Size after:
obd2.elf :
section size addr
.text 5586 0
.data 288 8388704
.bss 45 8388992
.noinit 0 8389037
.eeprom 6 8454144
.debug_aranges 20 0
.debug_pubnames 466 0
.debug_info 2225 0
.debug_abbrev 498 0
.debug_line 2234 0
.debug_str 691 0
Total 12059
AVR Memory Usage:
Device: atmega8
Program: 5874 bytes (71.7% Full)
(.text + .data + .bootloader)
Data: 333 bytes (32.5% Full)
(.data + .bss + .noinit)
-------- end --------
> Process Exit Code: 0
Wer kann mir da helfen?
Roland
BeitragVerfasst: Dienstag 7. Februar 2006, 16:32
Gast hat geschrieben:
Roland
Wieso Feher? Das sind warnings, die nur zur Information (über meinen schlampigen Programmierstil) sind. Entscheidend ist der Exit Code und der ist 0, also fehlerfrei. Demenstprechend wurde auch ein.hex-File erzeugt.
Mitglieder in diesem Forum: 0 Mitglieder und 13 Gäste
