Aktuelle Zeit: Montag 24. August 2026, 14:47
 Betreff des Beitrags: I/O-Board für µC mit AVR ATmega8
BeitragVerfasst: Donnerstag 8. Dezember 2005, 20:20
Hi!
I´m working in your project for elm323 Iso interface. I have the following problem with the display. When i connect power to the I/O board i need reset 2 or 3 times for the display work, the display nerver works at first time, but after the resets works great, i tested around 7 diferents displays and nothing. Maybe you know what happen with the display?
Thanks for any help.
Regards
BeitragVerfasst: Freitag 9. Dezember 2005, 12:13
I think it's a timing problem. The display is blank with full white blocks at all positions?
Try to edit some delays in lcd_tools.h
in lcd_flash_e ():
delay(10);
instead of delay(1);
and in lcd_ini ():
delay(16000);
instead of delay(10000);
BeitragVerfasst: Mittwoch 8. März 2006, 21:28
Hi, I have the same problems.
The lcd not init good.
I modificated lcd_tools but the problems not resolver.
Please help me.
BeitragVerfasst: Donnerstag 9. März 2006, 07:58
Without the Display I can't help you.
You must try to change the Init-Sequence by yourself. Probably you need other commands if you use an other LCD contoller.
BeitragVerfasst: Donnerstag 9. März 2006, 20:58
i need reset 2 or 3 times for the display work, the display nerver works at first time, but after the resets works.
thank you
Mitglieder in diesem Forum: Bing [Bot] und 11 Gäste
