Aktuelle Zeit: Dienstag 29. September 2026, 12:20
 Betreff des Beitrags: two kl interfaces on one OBD bus
BeitragVerfasst: Donnerstag 1. November 2007, 14:47
Hello, is it possible to connect two KL interfaces to one OBD bus. Would it cause too much load or interfere with the correct operation of the bus?
Thanks
BeitragVerfasst: Freitag 2. November 2007, 10:51
It is electrically possible but you can not send data with two interfaces in the same time.
BeitragVerfasst: Freitag 2. November 2007, 11:37
I tried it out, I actually have an ELM323 circuit from http://www.bynkaay.com/productdetails.jsp?PID=108 in my system at the moment but have now added the KL interface in parallel.
To ensure I did not overload the bus I ommitted R1 the 510ohm pull up on the K-Line from the KL interface.
I will run with the two in parallel until I migrate my software completely over to the KL interface.
In order to minimise the software changes I may write some functions to mimick the ELM323 9141 functionality but running over the KL interface.
BeitragVerfasst: Freitag 2. November 2007, 12:03
