Aktuelle Zeit: Dienstag 29. September 2026, 08:26
BeitragVerfasst: Montag 8. Dezember 2008, 19:26
I own and drive a rather rare car, and finding a original diagnostic instrument is practically impossible.
I have managed to locate and borrow one such instrument, and would like to dublicate parts of the simple functions - values reporting etc.
So I wonder - would I be able to use the "KL-Interface B (serial)" to monitor the communication between the original diagnostic instrument and the car? If yes, which software would be best for that task? And would it be enough with simple Y parallel connection to the existing cable connecting the car with the original diagnostic instrument be sufficient?
According to the car service manual all the ECUs in the car have a K and an L line. All the ECUs K and L lines have their own pins on the OBD connector, but the cable to the diagnostic instrument just connects all K lines to one “common” K line and all L lines to one “common” L line.
I have tried searching the forums, but my limited knowledge of German is not enough to find any meaningful info.
Best regards,
Nik
BeitragVerfasst: Dienstag 9. Dezember 2008, 08:54
It should be possible to monitor the communication with a KL interface on the "common" K and L line. Just try it with a terminal program like HTerm.
 Betreff des Beitrags: thanks and question
BeitragVerfasst: Donnerstag 11. Dezember 2008, 12:55
Thank you Florian!
I assembled the KL serial kit, made a Y cable and connected both the K and L line in parralel with the car - diagnostic instrument cable. Then used the HTerm program to log the communication. It all seems very logical... but I am unable to make any sense of it though. I tried reading all on your site regarding KL communication, with no clue. I managed to log this with 9600 setting for the serial port - could not select 10400.. Is it possible that the data is flowing with 10400 and I am basically getting garbage with my com port set to 9600?
The following is logged after requesting a specific set (Amper -2A, Volt 121V, Degrees 12C, Degrees 13C, Volt 14V, percent 80%, percent 30%, and five bits - yes and no) of parameters. I suppose that every 10 bytes message (or frame) contains all the parameters:
19:17:52.753:
8C8AFBD02B8C0315D283
19:17:52.964:
829395
19:17:53.294:
8CAAFFD02B8C03159297
19:17:53.495:
82D395
19:17:53.845:
8CAAFFD02B8C43159297
19:17:54.045:
82D395
19:17:54.396:
8C8AFFD02B8C0315921D
19:17:54.596:
82D395
19:17:54.947:
8C8AFFD02B8C0315923D
The following is the initialization:
19:17:43.050:
00
19:17:43.650:
00
19:17:44.452:
00
19:17:45.273:
95
19:17:45.323:
C4
19:17:45.363:
87
19:17:46.134:
82B1B3
19:17:46.464:
828CE6
19:17:50.280:
82B6B8
19:17:50.620:
8213FE
19:17:52.403:
829395
