Aktuelle Zeit: Samstag 19. September 2026, 02:20
 Betreff des Beitrags: COM Port Bits senden
BeitragVerfasst: Mittwoch 30. Mai 2012, 19:10
ich möchte einzelne Bits an meinen COM-Port senden. Im Prinzip 0-0-0-0-0-0-0-1 mit jeweils 200ms Abstand.
Mein Ansatz wäre jetzt:
#include <iostream>
#include <conio.h>
#include <windows.h>
int main(int argc, char* argv[])
    char INBUFFER[2]; // Create Input Buffer
    bool Zero = 0x00;
    bool One = 0x01;
    /* Komplement berechnen
    char Komplement = '\xd5' ^ '\xff';
    printf("%d\r\n",Komplement);
    DWORD        bytes_read    = 1;    // Number of bytes read from port
    DWORD        bytes_written = 1;    // Number of bytes written to the port
    HANDLE       comport      = NULL;  // Handle COM port
    int          bStatus;              // Status indicator
    DCB          comSettings;          // Contains various port settings
    COMMTIMEOUTS CommTimeouts;         // Contains various COM timeouts
    // Open COM port
    if ((comport =
         CreateFile("\\\\.\\COM4",                // open com4:
                    GENERIC_READ | GENERIC_WRITE, // for reading and writing
                    0,                            // exclusive access
                    NULL,                         // no security attributes
                    OPEN_EXISTING,
                    FILE_ATTRIBUTE_NORMAL,
                    NULL)) == INVALID_HANDLE_VALUE)
        printf("CreateFile() funktioniert nicht\r\n"); // error processing code goes here
        system("pause");
        exit(0);
    CommTimeouts.ReadIntervalTimeout         = -1;     // Timeout in ms
    CommTimeouts.ReadTotalTimeoutMultiplier  = 0;     // Timeout in ms
    CommTimeouts.ReadTotalTimeoutConstant    = 0;   // Timeout in ms
    CommTimeouts.WriteTotalTimeoutMultiplier = 0;     // Timeout in ms
    CommTimeouts.WriteTotalTimeoutConstant   = 65000;   // Timeout in ms
    bStatus = SetCommTimeouts(comport,&CommTimeouts); // Set COM timeouts
    if (bStatus != 0)
        printf("SetCommTimeouts() funktioniert nicht\r\n"); // error processing code goes here
    GetCommState(comport, &comSettings); // Getting COM state
    comSettings.BaudRate = 9600;           // COM setting
    comSettings.StopBits = ONESTOPBIT;  // COM setting
    comSettings.ByteSize = 7;           // COM setting
    comSettings.Parity   = ODDPARITY;    // COM setting
    comSettings.fParity  = FALSE;       // COM setting
    bStatus = SetCommState(comport, &comSettings); // Setting COM state
    if (bStatus == 0)
        printf("SetCommState() funktioniert nicht.\r\n"); // error processing code goes here
    Sleep(5);
    bStatus = WriteFile(comport, &Zero,1,&bytes_written,NULL);
    Sleep(200);
    Sleep(200);
    Sleep(200);
    Sleep(200);
    Sleep(200);
    Sleep(200);
    Sleep(200);
    bStatus = WriteFile(comport, &One,1,&bytes_written,NULL);
    printf("Sending: %d\r\n", 0x46);
    bStatus = ReadFile(comport,&INBUFFER,2,&bytes_read,NULL);
    printf("Receiving: %d <-> %d\r\n", INBUFFER[0], INBUFFER[1]);
    system("pause");
    CloseHandle(comport);
 return 0;
... allerdings ist WriteFile() nur für Bytes ausgelegt, kann ich irgendwie auch einzelne Bits senden? Der Code scheint so jedenfalls nicht zu funktionieren.
Danke & Gruß
COM
 Betreff des Beitrags: Re: COM Port Bits senden
BeitragVerfasst: Donnerstag 31. Mai 2012, 07:45
http://www.blafusel.de/obd/obd2_kw1281.html#5
BeitragVerfasst: Donnerstag 31. Mai 2012, 10:14
So ich habe mir mal den Source von WBH-Diag angeschaut und die Paketabfolge sowie Timing passt (ungefähr 8) ) soweit. Habe auch die 196ms genommen, weil ich ein USB-Kabel habe. Jetzt hänge ich an INBUFFER, kenn mich zum einen mit Delphi nicht aus und zum anderen habe ich kein Plan, wie sich INBUFFER in einer while-Schleife verändern kann, wenn ich INBUFFER verfolge lande ich bei myReadByte und folgich bei READBYTE. Woher holt der sich die Daten, aus einer Funktion, aus dem Handle?
Im Portmon sehe ich den Inbuffer nicht oder?
Danke & Gruß
COM
BeitragVerfasst: Donnerstag 31. Mai 2012, 11:03
Also mit INBUFFER meine ich die Antwort vom STG :
0x55 Sync Byte zum festlegen der Baudrate
0x01 key word LSB (low significant byte)
0x8A key word HSB (high significant byte)
