Aktuelle Zeit: Dienstag 29. September 2026, 15:48
 Betreff des Beitrags: PROBLEM in GSM remote switcher
BeitragVerfasst: Mittwoch 4. Mai 2011, 06:09
HI
I have tried to build the remote switcher but there is problem in the rs232 communication.
by viewing the output of the RS circuit on the hyper terminal it gives garbage values.
so what woulds be the possible solution to it.
can you send me the program or hex file of the RS switcher.
Dateikommentar: garbage value when connected to RS with baudrate 9600
untitled1213.JPG [13.88 KiB]
3653-mal heruntergeladen
 Betreff des Beitrags: Re: PROBLEM in GSM remote switcher
BeitragVerfasst: Mittwoch 4. Mai 2011, 07:40
You can find some info and downloads here: http://www.elektor.de/jahrgang/2008/nov ... ynkx?tab=1
BeitragVerfasst: Mittwoch 4. Mai 2011, 11:25
thanx for the help
can i connect the NOKIA 1208 instead of siemens c55
IF yes then the tx of the nokia 1208 to pin 2 of ATmega8 and rx =>pin3 right ??
1208_pinout2.jpg [12.52 KiB]
3640-mal heruntergeladen
BeitragVerfasst: Donnerstag 5. Mai 2011, 12:49
In most cases vice versa. RxD at Atmega is Input.
