Aktuelle Zeit: Samstag 15. August 2026, 09:22
BeitragVerfasst: Dienstag 15. April 2014, 17:58
Apologies for my non-existent German!
I have been trying to get my WBH-BT4 Adapter working with WBH-Diag and Torque Pro.
After getting connection errors I tried using Sena for terminal access. I can connect and run the commands atz and then atd02 with success.
But when I try atd01 it responds with the text "ERROR". I guess this is why I can't connect to this adapter with other software.
Is there anything I can do to connect to the ECU successfully to see error codes? I've seen some mention of a config file for WBH-Diag but have no idea if this will help or how to do it.
Many Thanks for any help,
Mark.
BeitragVerfasst: Dienstag 15. April 2014, 18:44
I'm close to a 100% sure that a WBH-BT4 does not work on a car made in 2008.
I'd say 2001 is the "newest" a car could be for that.
BeitragVerfasst: Donnerstag 24. April 2014, 16:41
Maybe this car use CAN. This is not supported by WBH BTx
