Aktuelle Zeit: Montag 27. Juli 2026, 06:06
Ein neues Thema erstellen Auf das Thema antworten  [ 48 Beiträge ]  Gehe zu Seite Vorherige  1, 2, 3, 4
 Betreff des Beitrags: Re: BT5 / TORQUE Feedback...
BeitragVerfasst: Samstag 13. Februar 2016, 12:41
I did not see any profit in this. It's a diagnostic device and there is no need for diagnostic to use a fast mode. The other problem is Bluetooth: It's not so fast as a cable connection can be (this is the reason why the firmware update need so much time instead of a update via cable).
Well, i'm very disapointed of this, because i don't use WBH BT5 for diagnostic fonction. It's for me a LOG tool.....so i see a lot of profit to make it the fastest as possible.
Never mind, i respect your point of view, about "YOUR" device....and you're right, the BT is probably a hard limitation in FPS...
I'll try to make my own with arduino.....
Thank's for all.
SKOLS
BeitragVerfasst: Donnerstag 18. Februar 2016, 17:12
we talked a little about missing features some posts ago. I'd like to add extended coding that I urgently desire for my Skoda Octavia (which does not work at all at the moment, I guess due to Can TP2.0/UDS).
SKOL, do you still have questions regarding that torque labelfile format? I just started adaption of my vans labelfile and had the first success with that. It's a little like the wbh-diag labelfile with an additional "short text" and the OBD-Pid.
Regards,
Christoph
BeitragVerfasst: Samstag 20. Februar 2016, 09:29
PölChris hat geschrieben:
In the future. There is no space in the chip for anything more.
