Aktuelle Zeit: Mittwoch 30. September 2026, 19:13
BeitragVerfasst: Montag 14. März 2011, 19:26
I am not completely clear on the BMW modification for the serial interface cable.
I understand the connections for DSR, RI and the 1.2k resistors to IGN and +UB
Is RTS replaced by DTR connected to the existing transistors and then to the 'L' line??
Is a schematic available for the BMW modifications?
BeitragVerfasst: Dienstag 15. März 2011, 00:12
only reading...
you must have an switch with common contact for the RTS/DTR cable.
is an three contact switch, the middle contact ist the contact from the pcb.
then you soldered the DTR/RTS cable on the switch left and right.
The other switch ist the connection between 7+8. This is only an On/Off switch.
At off the Bridge isn´t on, at On the Bridge is from 7 to 8.
The resistors are not important, you can use Inpa/Ediabas also without these resistors.
It´s better/professional, because the Programm behaves it like the original IF.
It shows professional... the LED in Inpa is checked, when ignition is on...
In Inpa/Ediabas are blinking a LED and says "Ignition Off", but you can ignore that, it works yet, at least in my case.
(without resistors)
I rebuild the Resistors too.
I have the same Interface...converted...
BeitragVerfasst: Dienstag 15. März 2011, 01:11
Thank you Bernd.
I think I understand. I only want to use it with BMW for now. So I will not need the switches.
Is the attached schematic correct for BMW only?
Werner
BMW 318ti //M
BeitragVerfasst: Mittwoch 16. März 2011, 10:56
I think it is OK .
BeitragVerfasst: Mittwoch 16. März 2011, 15:29
Thank you Bernd :)
Werner
BMW 318ti //M
