Aktuelle Zeit: Mittwoch 30. September 2026, 04:32
 Betreff des Beitrags: ELM communication with transmission
BeitragVerfasst: Mittwoch 20. Juli 2016, 17:12
Hi, I'm having problems communicating with the transmission (TCM). I'm using a clone ELM327, controlled by an Arduino Mega. Everything works fine communicating with the ECM (engine control module). My '06 Sprinter uses KWP2000 protocol.
I disconnected the ELM K-line output which connects to the OBD2 connector pin 3 (ECM K-line) and then connected ELM output to OBD2 connector pin 11 (TCM K-line).
I know the wake-up command for the TCM is: 81 20 F1 81 15
20 is the address for the TCM.
I also know the header for the TCM: 82 20 F1
My problem is getting the ELM327 setup. Here's what I'm doing:
ATZ
AT L1
AT E1
AT SP 5
AT SI
AT H1
AT KW
AT IIA 20
AT WM 81 20 F1
AT SH 82 20 F1
ELM's response to these commands is:
> ATZ: ELM327 v1.5
>AT L1: OK
>AT E1: OK
>AT SP5: OK
>AT SI: ?
>AT H1: OK
>AT KW 0: ?
>AT IIA 20: ELM327 v1.5
>AT WM 81 20 F1 81: ?
>AT SH 82 20 F1: OK
The "?" means I'm using the wrong protocol or I have a typo. However, I'm using protocol 5 which is KWP2000, and AT KW 0 should be OK. The response from AT IIA 20 is also strange. :nixweiss:
With this setup, the ELM sends on the K-line this wake up command: C1 33 F1 81 66
That is the wake up command for the ECU.
Has anybody communicated (using an ELM clone) with another module other than the engine? Can it be done?
Thanks
Mitglieder in diesem Forum: Bing [Bot] und 45 Gäste
