Aktuelle Zeit: Dienstag 30. Juni 2026, 19:33
BeitragVerfasst: Donnerstag 4. Juni 2015, 21:20
First post, and my apologies its in English.
Background
I have a 2006 VW T5 with a generic Elm 327 OBD2 USB interface. This connects to Dashcommand, and it reports an ISO-14230 protocol connection. It works, but only displays engine revs, speed and coolant temperature.
ISO-14230 /KWP2000 uses pin 7 of the OBD2 port I understand for K-line. I also understand VW use a version of KWP2000 - KWP2089. The generic Elm 327 cannot read KWP2089, so I'm looking for a better interface.
VW T5 2006 - WBH BT5 - Dashcommand - Solution?
So, my question: Is a WBH BT5 the solution?
If it is, I understand it needs to be ELM 327 compatible and report on the expanded (KWP2089) protocol.
I would be very grateful if anyone can offer their advice before I make the purchase.
Many thanks, Danke,
Tony
(UK)
BeitragVerfasst: Montag 8. Juni 2015, 08:41
The WBH BT5 supports KW2098 via CAN TP2.0 You can use it like a ELM https://www.obd2-shop.eu/files/whh-diag ... -sheet.pdf
Mitglieder in diesem Forum: Bing [Bot] und 8 Gäste
